Abnormal program termination
Hi team,
I am Kannan, working as a senior engineer in WSP. I have done grillage analysis using Autodesk structural bridge design as per British standards. I have encountered the below errors while using the software. Could you please look into this and provide your guidance to fix the issues ?
Sl.No | When | Error Type |
1 | When trying to run the load optimisation to CS 454 |
2 | When clicking the result dropdown list |
3 | When closing the result window. |
As CS codes supersedes the BD, It will be helpful if CS 458 code is also available in the influence surface generation
With Thanks & Regards,
Kannan M K
Mob +91 9600081008
