Abnormal program termination
Kannan.KuppusamyPUP4R
Observer Observer
Observer
Observer
Hi team,
I am Kannan, working as a senior engineer in WSP. I have done grillage analysis using Autodesk structural bridge design as per British standards. I have encountered the below errors while using the software. Could you please look into this and provide your guidance to fix the issues ?
Sl.No
When
Error Type
1
When trying to run the load optimisation to CS 454
2
When clicking the result dropdown list
3
When closing the result window.
As CS codes supersedes the BD, It will be helpful if CS 458 code is also available in the influence surface generation
With Thanks & Regards,
Kannan M K
Mob +91 9600081008
dave_geeves
Hi Kannan,
I'm not sure I can be of much help here as it seems to be an internal problem with the software.  I do know however that a number of C454 optimisation issues were fixed in the latest hotfix for the 2023 version which may include the issue that you are describing so it may be useful to upgrade to that version and try it.
What version are you experiencing the problem with?
If you are using the latest version, then I think the developers will need to inspect your data file to be able to reproduce the problem so could you please zip up your data file (together with any other linked files if appropriate) and attach it to a reply to this post to help the developers.  If you do this, I will also take a look to see if there is any workaround to this issue.
Sorry I can't be of more help.
Kind Regards.
Dave Geeves
simon_hooper
Hi Kannan
As Dave indicated, the latest update should fix the load optimisation issue you were having. Go to your account (manage.autodesk.com) and install the latest hotfix (version 23.0.2).
Regarding the Tabular Results issue, I haven't been able to reproduce this.  Please could you see if this happens in 23.0.2 and if it does, then send a full screenshot.  I would like to see how your graphics window is docked or if it is floating.  The RecordIndex issue could be linked to the first issue.  If it is reproducible could you reset your settings via the Options | Preferences form "Reset Application Settings" button on the General tab.
With regards to the CS 458 query.  This is on our backlog but there is no timeframe I can share at this time.
Simon
Simon Hooper
Software Development
Observer
Observer
Thanks a lot Dave Geeves.
Apologies for the delayed response.
I am currently using Structural Bridge design 2022 (version 22.1.1.22). I have attached the relevant zip files for your further actions.
As I don't have the latest version, i could not see it happens in the 23.0.2 version. I am following up with my IT team to get the latest one, if i see any error will let you know.
kannan
