Stingray Forum (Read Only)
Welcome to Autodesk’s Stingray Forums. Share your knowledge, ask questions, and explore popular Stingray topics.
Moving/flying freely in VR model? (using Oculus Rift and Xbox-control)
5 REPLIES 5
1583 Views, 5 Replies
Hi!
I'm using Stingray and creating VR-models. I want to be able to "move/fly around freely" in my level, preferably using an Xbox-control (or maybe keyboard + mouse) while in Oculus Rift. By following Paul's great tutorials (linked below) I'm able to move in X- and Y-axis using the left thumbstick on my Xbox-control. However, the tutorial doesn't explain how to add the movement of up and down. So I freestyled an additional piece of Flow-code for the right thumbstick, affecting the Z-axis, but I haven't changed any code in lua for this. The problem I have is that I can't use both thumbsticks simultaneously, everytime I move a thumbstick I jump back to the starting position of my level. But independently the thumbsticks work as they should. Does anyone know how to combine the thumbsticks so they can work simultaneously? I attached screenshots of how it looks in Flow. The lua code is the same as in Paul's tutorials.
Paul's tutorials that I mentioned above:
https://www.youtube.com/watch?v=GVB7JFH_dMo
https://www.youtube.com/watch?v=7pjDbmVH0uE&feature=youtu.be
Thank you and best regards,
Victor
5 REPLIES 5
Tricky to say without really sitting down on the project myself, but on just a glance it looks like you're not passing the z axis of the current tracking space when you're using the left stick and not passing the x and y of the current space for the right stick.
Only your left stick flow i'd try connecting the z vector components from your oculus get tracking space to the z in the vector from components after the addition nodes. I think what your're basically doing a the moment is resetting the z axis to 0 whenever you use the left stick, so just passing it through from what it currently it should help.
And the same goes for your right stick, connect up the x and y from the vector components to the vector from components down the line.
See what that does!
IMDesigns
I've implemented that. Feel free to use mine, I also learned from Paul. You've run into a common mistake (I also did that) with your Right Stick, in the first Vector Components, you should use Y instead of Z to control height (no need to use rotation by the way) and X if you want to turn with the controller as well.
Let me know if that solved your issue.
Best regards,
in reply to: IMDesigns
Best regards,
Thank you! Your code works perfect for my project!
Best regards,
Victor
Shawn_Hendershot
Does anyone know how to change from using the xbox Thumbstick for fly mode to using the Oculus thumbstick inputs?  I have the xbox controller working perfectly.
I also tried following the tutorials of Paul, however I keep getting this error with the HTC Vive when moving the thumb stick of the XBOX controller. Does anyone have an idea how we can solve this error?
Test Engine / SteamVRPlugin: SteamVR.set_tracking_space_pose(Matrix4x4) is deprecated. Use SteamVR.set_tracking_space(Vector3, Quaternion, Vector3) instead.
