How to hidden outline
teachung
teachung
I use Desktop VR template to create a scene.
when I use Gamepad touch anything, the object will show a green outline.
Shanii2
it is actually a selector function that gives the masked outlines, and you usually help for point clicking and selecting but you can disable it... as its just a flow node which gives masked outline to anything your hand controller is going to touch or ray cast collide..  You need dig deep into your flow nodes structure and also flow subroutines to find the funtion which is casting it.
teachung
I found out solution.
same issue od this post.
https://forums.autodesk.com/t5/stingray-forum/floor-highlights-in-vr-unwanted/m-p/8285245#M11138
 If both of the Vive controllers are on, then you don't get the outline.  If one is off, you will.
I think when one controller be on, stingray will think another controller on the floor.
Bez controller touch floor always, stingray show floor outline always .
