Trigger not working
Trigger not working
Trigger not working
I am new in stingray, as i try Door Animation Trigger with Stingray Video Link.
https://www.youtube.com/watch?v=C87RV3khOoU&list=PLTjhBiJe1i2GoE_qDkh7vEZCTUZnR77zg
I have done animation and create a level in stingray and same as video i gave connection but still trigger not working.
My attachment is with post.
page_01.JPGpage_02.JPGpage_03.JPGpage_04.JPGpage_05.JPGpage_06.JPGpage_07.JPGpage_08.JPG
VincentSheehan
Have you looked at the Shape Template of the trigger shape?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Thanks Vsheehan,
I already change Actor Template as Static and Shape Template Character_trigger.
but still same as problem trigger not working.
What's colliding with your trigger? Has the player got a mover/physics actor that is moving with it?
How are you also triggering the animations? Use a physics trigger node and specify the physics actor in the name input, and on 'enter' play f the open animation and on 'leave' play the close animation.
In my experience physics triggers work with the physics actor of the player, so make sure your physics actor for the player is moving with it. Use a get actor position node and print that to screen to test.
Got the solution, I didn't place base on below the door.
