Scaleform Progress Bar
Howdy All,
I can't seem to find a way to update Scaleform Progress Bar through Flow or Lua. If there are additional documentation on how to set this up that would be Awesome!
Cheers
I found a Progress Bar example along with some other widget examples, in
C:\Program Files\Autodesk\Stingray\1.2.564.5\editor\ScaleformStudio\content\projects\WidgetCollection\WidgetCollection.s2dproj
My exercise is to turn a Progress Bar into a Health Bar. I hope to come up with something. If anyone has a solution to this exercise feel free to post. 😃
Yup... great scaleform widget examples in WidgetCollection.s2dproj file.
I confess I am so new to game programming... can someone explain the intent for these lines of code from Progress Bar Widget.lua
scaleform.AnimationComponent.goto_label(mainContainer, "started");
scaleform.AnimationComponent.goto_label(mainContainer, "normal");
This is a lua code to make a Progress Bar into a Health Bar using the ProgressBarWidget. If it does not work, drop me a line.
-- IMPORTANT: This script resource may be attached to all progress bar widgets created by the Widget Creator panel.
--            If modifications are required, then first copy this file to a unique path and fix all necessary
--            script components' resource paths.
--[[ Create this Function in any *.lua file but make sure there is a 'require' associated with it,
in my case its in Project.lua so no 'require' needed. Then you can call it in Flow. function Project.updateShipHealth(myVar) local actorProgressBar = scaleform.Stage.actor_by_name_path("Scene0.Ship_Health_PB"); local widget = scaleform.Actor.component_by_name(actorProgressBar, "WidgetBase"); local widgetApi = scaleform.ScriptComponent.script_results(widget); widgetApi.setProgress(myVar); end ]]-- -- Modified ProgressBarWidget.lua
local thisActor = ...; local currentProgressBarPercentage = 101; scaleform.Actor.set_mouse_enabled_for_children(thisActor, false); local emitEvent = function(func, param) local comp = scaleform.Actor.component_by_name(thisActor, "WidgetHandler"); if comp ~= nil then local handlerObject = scaleform.ScriptComponent.script_results(comp); if handlerObject ~= nil then if handlerObject[func] ~= nil then if (param) then handlerObject[func](param); else handlerObject[func](); end end end end end -- Helper function to set the current progress of the widget (0 to 100) local setProgress = function(progressPercentage) if (progressPercentage < 0) then progressPercentage = 0; end if (progressPercentage > 100) then progressPercentage = 100; end local mainContainer = scaleform.Actor.container(thisActor); -- Process only if progression has changed. if (currentProgressBarPercentage ~= progressPercentage) then currentProgressBarPercentage = progressPercentage; if (currentProgressBarPercentage > 0) then if (currentProgressBarPercentage == 100) then emitEvent("started"); end --scaleform.AnimationComponent.goto_label(mainContainer, "started"); else --scaleform.AnimationComponent.goto_label(mainContainer, "normal"); end if (currentProgressBarPercentage > 0) then local bitmap = scaleform.ContainerComponent.actor_by_name(mainContainer, "bitmap"); if (bitmap) then scaleform.Actor.set_local_scale( bitmap, {x=currentProgressBarPercentage/100.0, y=1.0} ) ; emitEvent("onProgress", currentProgressBarPercentage); end end if (currentProgressBarPercentage <= 0) then --Old version if (currentProgressBarPercentage == 100) then emitEvent("complete"); end end end -- Helper function to increment the current progress of the widget (0 to 100) local incrementProgress = function() if (currentProgressBarPercentage < 100) then setProgress(currentProgressBarPercentage+1); end end -- Helper function to reset the current progress of the widget. local resetProgress = function() --setProgress(0); setProgress(100); end -- Helper function to get the current progress of the widget. local getProgress = function() return currentProgressBarPercentage; end -- Save the methods below in this script component to use them from elsewhere local exports = { incrementProgress = incrementProgress; setProgress = setProgress; resetProgress = resetProgress; getProgress = getProgress; } return exports;
paulkind
Hi Joseph
If you double click within the widget you will notice there is an animation timeline in there.
Both of these lines are telling to the animation component to set the playhead (goto_label) within the timeline of the animation component to jump to "started" and "normal" respectively.  Markers are on the timeline in this case within "AnimationComponent" and are used to designate a specific frame within an animation.
Paul
Areas of Expertise - MayaLT : Mudbox : 3DS Max : Inventor : Game Dev
Follow me on Twitter : @paulkind3d
Please remember to give kudos freely and mark acceptable answers as solved!
PLEASE do not send me private messages unless asked to do so. If you have a question, start a thread, and ask me on the public forums where answering your question may help others.
Did you know there was a YouTube learning channel for Autodesk Games? New videos are posted regularly with all sorts of content relative to Stingray, Maya/MayaLT, 3DS Max, and other game related tools. Get your game on @ https://www.youtube.com/user/autodeskgameshowtos
Paul,
Oh interesting. The progress bar widget defers to the animation timeline as a form of measurement.
Thanks!
Shanii2
I think i found away to create a custom progress bar of any shape or sizes instead of straight bar. and without use of code 😉 ..  for this
 Create a background actor with total dimension of the actual length of progress bar.
 Make it animation component container to contain more actors.
 Now add a bitmap image  fill color to fill the background of same size in width and height..
You can further use animated type as well. in form of fill
Now dublicate the background layer and it as a masking layer to mask the fill layer..
Keep the mask over to the side so that its no longer covering the fill. make sure the masking layer is of same size as that of background.
Go to the timeline of masking layer and mark keyframes from 1 to 100 frames.
Now animate the mask layer at 1 frame to just a bit over the fill to reveal small amount i.e (1%)..  and at 100.  move it along all the way over the fill i.e 100%
Now mark each step on timeline  so that at every frame you get increamental orders of percentage over timeline And Wollahh!!..  you have custom progress bar. Now you just have to send command to go to such and such frame on timeline and you'll get the progress of it because you have divided your timeline of 100 frames as a form of measurement and you can directly plug the number of frame to play based of any increamental stages you want.
 For Continues progress bar instead of marking each frame ad linear tween between 1 to 100 frames  and at stop action at frame 1 and whenever you want to start just set it to go to frame 2 to play as continues progress bar..
with this structure you can have any style of progress bar as either rectangular, circular, spherical, fills etc its only a matter of how you animate the mask layer. 🙂
