Hi Guys, I have just downloaded 3DS Max Interactive and really excited to try build some environments using my HTC Vive. The headset is working fine with other programs. However for 3DS Max Interactive it has a problem displaying the scene created using the Vive template. The scene is running on the PC but doesn't load into the Vive. Any advice will be much appreciated ....
Hey James,
It should be working fine. Is the light on the side of your HMD (Head Mounted Display) red or green when you test the project? Also is the scene tracking the HMD movements and just not showing it on the screen or nothing is happening at all?
Hi Ben, thanks for responding. The Vive is working great, Led light on side of headset is green, tracking stations are aligned and green. I can go into other applications and use the headset. What I noticed is that when I go into a 3DS Max Interactive template and run the VR it comes up with a box which shows the room on the PC screen and when I move the Vive headset it moves the scene within the Box on the PC screen but nothing in the headset. The other thing I noticed is that the mouse and PC trackpad function is disabled at when the box is open and the only way to return back to the main program is to press escape. Not sure if thats related to the problem or not.
Other than the black display everything else is behaving as it should
Do you get any errors/messages of interest in the Log Console?
I have a few follow-ups
It is the the key point!
