Stingray Forum (Read Only)
Welcome to Autodesk’s Stingray Forums. Share your knowledge, ask questions, and explore popular Stingray topics.
How to load project other than the template into Stingray?
6 REPLIES 6
687 Views, 6 Replies
How do you get the sample programs to run in Stingray?  (Traffic_v1, top-down-space-shooter, subwayv1, and humanik)
6 REPLIES 6
Start the engine and select 'Add Existing' in startup menu. Then select the folder, where the project is. Take care not to select one with _wwise ending.
Thanks!! What happens if you select the one with _wwise ending?
Audio-Design
Hi thomalex89! Assuming you have downloaded the project from creative market. In the project launch (appears after you open stingray) click the button "add existing", then navigate to the location where you have downloaded the project and select the folder!!
Audio-Design
if you select the _wwise nothing will happen really, your project just will not load.
in reply to: Audio-Design
Thanks I got it.  I remember hearing that in the video now.  I was just a little frustrated trying to learn Stingray.
andrew.grant
thomalex89, sorry you are frustrated!
The stingray project is the folder that contains 'settings.ini'.
