Hi
I'm not sure what's happened but basically every time I attempt to "run project" on 3DS Max Interactive it just crashes with no hesitation and no error message.
I've tried the "Test level" button and that works fine. I'm not sure what's caused this.
I've even created a new project, imported the model and attempted that but it still crashes. It's not heavy on my RAM I'm very confused.
Please help!
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
Solved by hagen.deloss. Go to Solution.
Hi @Anonymous
Great to hear from you on the forums! I'm wondering if you have used any of mesh cleanup tools in the modeling package you are using? It could be that some hidden/overlapping faces, or errant vertices are causing the crash.
If you are using 3DS Max, I would suggest using Xview to isolate problem areas on your mesh just to double check.
I will follow up with you shortly, looking forward to chatting with you further!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Thanks for your reply!
It doesn't seem to be a problem with 3DS Max (the modelling package I'm using).
3DS Max Interactive/Stingray seems to have the data compiled but then as it attempts to run the target, it crashes. It doesn't show in the log console as the program crashes overall.
Sylvian
Sylvian
@Anonymous
I just want to make a note, I would refrain from posting your email address on the public forum, you can send it to me via a private message in the future 😄
I have a few questions to narrow things down further.
Would you be able to send me the model you are trying to load into 3DS Max Interactive? I can attempt to recreate the crash on my end. Feel free to upload your file in a zip folder, or send me a file sharing link via a private message.
Hagen Deloss
Unfortunately I'm not allowed to release the model as its for work. But I will try the suggested ideas and let you know the outcome. For now I'll mark the solution Thanks!
@Anonymous
That makes sense! If you encounter this crash issue in the future with a model you can share, feel free to send it my way. If you have any other details regarding the crash, that would be super helpful!
The crash report you submitted didn't bring up enough information for use to determine the exact issue, its a roll of the dice sometimes.
Hagen Deloss
