Deployment problem
Deployment problem
donied
Deployment problem
donied
I have just started playing with Max Interactive. Set up a new project using the basic template I have brought in a basic building from Max . Saved my building to a new scene
When I run or deploy my project it runs the basic level with the yellow cube not my level. If I test the level it works fine. How can I get the program to deploy my level
paul.kind
Oh, that is just because you have not told your project to load your level.  This is an easy fix (just not very obvious).
Heres what you need to do.
1.  locate the following file and open it.
script/lua/project.lua
2. Change the line that says
basic = "content/levels/basic"
and change it to the path of your level liks so...
basic = "content/levels/my_awesome_level"
Save and hit run project.
Areas of Expertise - MayaLT : Mudbox : 3DS Max : Inventor : Game Dev
Follow me on Twitter : @paulkind3d
Please remember to give kudos freely and mark acceptable answers as solved!
PLEASE do not send me private messages unless asked to do so. If you have a question, start a thread, and ask me on the public forums where answering your question may help others.
Did you know there was a YouTube learning channel for Autodesk Games? New videos are posted regularly with all sorts of content relative to Stingray, Maya/MayaLT, 3DS Max, and other game related tools. Get your game on @ https://www.youtube.com/user/autodeskgameshowtos
donied
Thanks for your reply. I have tried that and it doesn't work
Project.level_names = {
menu = "content/levels/main_menu",
basic = "content/levels/ChaletS"
I have tried shutting down and reloading
paul.kind
Hrm, so just to ask a fairly obvious question....   is your level saved in the levels folder?
Paul
donied
No problem for he obvious question. Because I'm probably not doing something really simple.
Yes it is saved to the Levels folder beside the basic Level
@paul.kind
I know this was an old post, but it saved me last night when I was run up against a hard deadline, thanks!
