- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I try to compile a project for Gear VR, but get the following error:
Editor / General: Android Packager: Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.AndrolibException: brut.common.BrutException: could not exec: [aapt, p, --forced-package-id, 127, --min-sdk-version, 21, --target-sdk-version, 25, --version-code, 1, --version-name, 1.0, -F, C:\Users\ANDREA~1.JAN\AppData\Local\Temp\APKTOOL13100425274353655554.tmp, -0, arsc, -0, arsc, -I, C:\Users\andreas.janson\AppData\Local\apktool\framework\1.apk, -S, C:\Users\andreas.janson\AppData\Local\Temp\tmp8077.tmp\deploy\res, -M, C:\Users\andreas.janson\AppData\Local\Temp\tmp8077.tmp\deploy\AndroidManifest.xml] at brut.androlib.Androlib.buildResourcesFull(Androlib.java:478) at brut.androlib.Androlib.buildResources(Androlib.java:412) at brut.androlib.Androlib.build(Androlib.java:311) at brut.androlib.Androlib.build(Androlib.java:264) at brut.apktool.Main.cmdBuild(Main.java:227) at brut.apktool.Main.main(Main.java:84)
I have installed the latest android sdk on my computer and I have set up the environment Variable ANDROID_HOME.
I have created and attached the oculus signature.
I have set the Android flavor to GearVR.
Any ideas what could be the problem?
Regards
Andreas
