Good work on the Scaleform project, you're almost there.
Here's a way you can modify the main_menu.lua file to pick up the "ZoneX" message coming from Scaleform.
Customized functions for controlling what happens for a particular loaded level.
These classes should define any of
init(level)
start(level)
update(level, dt)
shutdown(level)
render(level)
local Util = require 'core/appkit/lua/util'
local SimpleProject = require 'core/appkit/lua/simple_project'
local DebugMenu = require 'core/appkit/lua/debug_menu'
Project.MainMenu = Project.MainMenu or {}
local MainMenu = Project.MainMenu
MainMenu.custom_listener = MainMenu.custom_listener or nil
MainMenu.action = nil
local start_time = 0
local function perform_action()
-- Load empty level
if MainMenu.action == "start" then
MainMenu.shutdown()
local new_level_name = MainMenu.new_level_name or "content/levels/Zone_1"
SimpleProject.change_level(new_level_name)
MainMenu.new_level_name = nil
-- Exit the program
elseif MainMenu.action == "exit" then
stingray.Application.quit()
end
end
function MainMenu.start()
if stingray.Window then
stingray.Window.set_show_cursor(true)
end
if scaleform then
scaleform.Stingray.load_project_and_scene("content/ui/simple_menu.s2d/simple_menu")
--Register menu button mouse listener
local custom_listener = MainMenu.custom_listener
custom_listener = scaleform.EventListener.create(custom_listener, MainMenu.on_custom_event)
MainMenu.custom_listener = custom_listener
scaleform.EventListener.connect(custom_listener, scaleform.EventTypes.Custom)
else
local enter_game = function()
MainMenu.action = "start"
perform_action()
end
local exit = function()
MainMenu.action = "exit"
perform_action()
end
MainMenu.debug_menu = DebugMenu(SimpleProject.world, {
title = "Main Menu",
items = {
{text="Enter Game", func=enter_game, target=nil},
{text="Exit", func=exit, target=nil}
end
local level = SimpleProject.level
start_time = stingray.World.time(SimpleProject.world)
-- make sure camera is at correct location
local camera_unit = SimpleProject.camera_unit
local camera = stingray.Unit.camera(camera_unit, 1)
stingray.Unit.set_local_pose(camera_unit, 1, stingray.Matrix4x4.identity())
stingray.Camera.set_local_pose(camera, camera_unit, stingray.Matrix4x4.identity())
Appkit.manage_level_object(level, MainMenu, nil)
end
function MainMenu.shutdown(object)
if scaleform then
scaleform.EventListener.disconnect(MainMenu.custom_listener)
scaleform.Stingray.unload_project()
end
MainMenu.evt_listener_handle = nil
Appkit.unmanage_level_object(SimpleProject.level, MainMenu, nil)
stingray.Window.set_show_cursor(false)
end
end
function MainMenu.on_custom_event(evt)
if evt.name == "action" then
if evt.data.message:find("^Zone%d") then
MainMenu.new_level_name = "content/levels/" .. evt.data.message
elseif evt.data.message == "exit" then
end
end
end
-- [[Main Menu custom functionality]]--
function MainMenu.update(object, dt)
if MainMenu.debug_menu then
MainMenu.debug_menu:update()
end
if MainMenu.action == nil then
local time = stingray.World.time(SimpleProject.world)
local p = stingray.Application.platform()
if time - start_time > 1 then
if Appkit.Util.is_pc() then
if stingray.Keyboard.pressed(stingray.Keyboard.button_id("1")) then
MainMenu.new_level_name = "content/levels/Zone1"
elseif stingray.Keyboard.pressed(stingray.Keyboard.button_id("2")) then
MainMenu.new_level_name = "content/levels/Zone2"
elseif stingray.Keyboard.pressed(stingray.Keyboard.button_id("esc")) then
end
elseif p == stingray.Application.XB1 or p == stingray.Application.PS4 then
if stingray.Pad1.pressed(stingray.Pad1.button_id(Appkit.Util.plat(nil, "a", nil, "cross"))) then
elseif stingray.Pad1.pressed(stingray.Pad1.button_id(Appkit.Util.plat(nil, "b", nil, "circle"))) then
end
end
end
end
perform_action()
end
return MainMenu
There are two main changes I made.
In on_custom_event(), which gets triggered by the event listener on the Scaleform project, I look at the name of the message coming from Scaleform and see if it starts with "Zone" followed by a number. If so, I save that desired level name in MainMenu.new_level_name and call perform_action() to do the level swap.
I also changed perform_action() so that when the "start" event is detected, it reads the level it should start from that new_level_name variable, instead of just always starting the basic level.
Also, if you want to support starting a numbered zone level from pressing the number keys, you might want to change the update() function to copy the
block once for each zone, and update the button ID and the new_level_name there.
