Softimage Forum (Read Only)
Welcome to Autodesk’s Softimage Forums. Share your knowledge, ask questions, and explore popular Softimage topics.
Switch between PPG Items
2 REPLIES 2
643 Views, 2 Replies
Hi.
A couple days ago i just mention that there is no hotkeys that helps switch between PPG items.
I mean there is no functional hotkey in Softimage that helps switching between the PPG items just like the TAB hotkey in Windows do.
For example it would be greate to apply bevel\extrude\push etc , press hotkey and scroll it's value in PPG.
It's faster then each time after you use modelling tool, point to its PPG item with mouse.
I tried to find something similar in documentation but can't find "active" attribute for PPG item.
Is there any way to add this functionality to softimage ?
Some script, plug-in or something ?
Tags (1)
2 REPLIES 2
It would be an intersting feature to have (in case ADSK decided to get Soft back :/)
For now I don't think this is possible with standard XSI widgets. Maybe you can have this functionallity with custom plugins that have QT or WPF for UI.
Nice timing. 1,5 year for answer )))
Technology Administrators
