Softimage Forum (Read Only)
Welcome to Autodesk’s Softimage Forums. Share your knowledge, ask questions, and explore popular Softimage topics.
Implict Selection
9 REPLIES 9
Message 1 of 10
306 Views, 9 Replies
Implict Selection
How do i get the currently implicitly selected object when using a sub component filter on an object, such as Polygon Filter on a Polygonal Mesh.
Selection only returns sub components in this case, and when none is selected i can't look up their parent either.
This is just convenience for a conditional selection script, eliminating the step of having to step out of the current filter and select the object.
9 REPLIES 9
Message 2 of 10
logmessage Selection(0).Name
I think should work for you
Chin
PS I find using the SDK Explorer amazing for this type of info. It has helped me so much in the past. If you don't use it already I highly recommend it!
Cntrl+Shift+4 = hotkey
Message 3 of 10
Stephen.Blair
If you want to get the X3DObject directly:
LogMessage( classname(Selection(0).Subcomponent.Parent3DObject) );
// Stephen Blair
// Arnold Renderer Support
Message 4 of 10
Selection(0).Name, // ERROR : Object required - (In Vertex and Edge Filters, Polygon Filter returns a valid name.
The latter requires a component to be selected tho.
Guess a fair compromise is to either have the user select an object, or add to the current selection.
Message 5 of 10
Ah I did not realise you meant when no component selected. This is a workaround:
set sel = Application.Selection
set currentFilter = sel.Filter
logmessage currentFilter.Name
ActivateObjectSelTool
LogMessage Selection(0)
'Set back to the current filter
if currentFilter.Name = "Vertex" then
ActivateVertexSelTool
elseif currentFilter.Name = "Edge" then
ActivateEdgeSelTool
elseif currentFilter.Name = "Polygon" then
ActivateRaycastPolySelTool
end if
Message 6 of 10
Thanks Chinny, Actually works quite well.
var filter = Selection.Filter;
SelectObjectFilter();
var objectName = Selection(0).Name;
LogMessage( objectName );
SelectFilter(filter);
var object = ActiveSceneRoot.FindChild(objectName);
LogMessage( object.Name );
I'll try to put the script in a presentable form sometime next week 🙂
As a side note, just trying to match XSI's behaviour.
Should the script be expected to work with multiple objects? Seems like i.e the select n-sided polygons is able to work with multiple objects. (Just a user leisure question)
Edit: Wait, why am i traversing the scene to find the object when i have it right there in Selection?
A Cleaner version would obviously be
var oObject = Selection(0);
Message 7 of 10
Another side note, Point::Position seem to hold relative (local transform) values?
How do i get absolute values? 😉
Edit: Yet another thing. is there a C++ equivalent to SelectFilter? digging trough the docs i can't seem to find a method to set the selection filter.
Message 8 of 10
Perhaps XSIMath.MapObjectPositionToWorldSpace?
Message 9 of 10
Still looking for a way of setting the current selection filter using the object model as Selection.Filter is read only.
Message 10 of 10
Ended up just writing a wrapper using Application.ExecuteCommand.
