I downloaded the tar.gz file from the account. It unpacks into many smaller archives inside folders.
In that main folder is a setup file that I can run as root. But it does not setup Softimage it just runs a text mode setup utility that says to choose a tool and I have
authentic configuration
firewall configuration
keyboard configuration
network configuration
system services
RUN TOOL
or QUIT.
None of these options actually installs Softimage even though in the PDF file it says to run the setup file.
There is a cdinst.dat which looks like it actually would do the proper install work unpacking the files for me.
I am on a centOS machine. I have run a maya install as well as many other software installs on linux with no problems many times.
This Softimage installer is a bit of a puzzle. If you could point me to the proper installation method since the pdf only leads me to run the above tool menu and not actually installing softimage at all.
Thanks. ๐
Solved by TimberVFX. Go to Solution.
nevermind.
I was running setup not as a binary.
For future reference...
donยดt type ยจsetupยจ instead type ยจ./setupยจ
