I do not have this software, but I was wondering if this program has the capability to do the following:
You have an angioplasty balloon assembly, which is made out of two balloons. Intially, the two balloons travel down the main artery, but after a time the lower balloon goes down the branch artery
but the main balloon (top) stays in the main artery. all the time the lower balloon must stay inside the assembly. At present this is a 3ds Max scene, but you can see the problems. ZMy question is can softimage do a better job? I am using path deform .
See attachment for problem
