Addon messing up my preferences
This widget could not be displayed.
Hi Guys,
Im new to XSI and I have to say that im really enjoying learning this tool. I really hope that in the future I can post some WIP and share it with you guys.
As expected I have a lot of questions but i wont bother anyone yet with things that I know that are already out there, but there is one thing that have been bothering me a lot, and I cant find a way to fix.
I have XSI mod tool version 6 2007.0814, and for some reason I updated it some weeks ago, and now an AddOn was installed called Mod_Layout ( or maybe was already there but i never noticed ) and this AddOn always change my preferences. I really with to leave my layout as the Mod Tool Default, but everytime I open the program, or if I create a new scene, my preferences change to the ones set by this Mod tool. I didnt tried to install again, and i dont plan to as i have a few projects set up and im afraid I might mess up the paths in my project manager.
Can anyone give me a hand, much appreciated.
Stephen.Blair
The ModTool doesn't reset the layout.
Maybe your preferences are not being updated.
After you exit, check C:\Users\XXXXXX\Softimage\XSI_6 Mod Tool\Data\Preferences\default.xsipref
In default.xsipref, this line specifies the layout you see at startup:
xsiprivate.UI_LAYOUT_DEFAULT = Default
// Stephen Blair
// Arnold Renderer Support
Stephen thanks for the tip.
There is indeed something funny happening there.
I exit mod tool and opened the file and thats what I got at that line:(mod tool closed)
Now with Mod tool back opened heres what happen...
The layout selection is still not what i had before: View > Layouts > Mod_Layout and not the default as I wanted
O now with mod tool still opened I opened default.xsipref and rechecked the line:
After checking got Mod tool closed and reopened the file default.xsipref:
voila: xsiprivate.UI_LAYOUT_DEFAULT = Mod_Layout
Funny heh... yes 🙂 , and of course if I open mod tool once more, the layout is set to Mod_layout, and in my default.xsipref file the line says Mod_layout too
Any other idea? (hope so :biggrin:)
Thanks again
Stephen.Blair
I can't remember whether I modified my ModTool install to prevent this behavior. Let me reinstall the ModTool addon and check.
// Stephen Blair
I have deleted already the Mod Tool add-on from File > Add-on > Uninstall
But for some reason Mod_layout is still there.
Is there a way to completely remove all data from the Mod tool add-on beside what I have done already? By the way i had the trouble deleting the layout file Mod_Layout.xsilystate from \Softimage\XSI_6 Mod Tool\Application\layouts but for some reason the file keeps appearing back again.
Im really thinking about re-installing xsi, lets say that I do that will I loose my projects in my project manager?
Stephen.Blair
Just disable the ModTool Startup event.
Edit the file C:\Softimage\XSI_6_Mod_Tool\Addons\ModTool\Application\Plugins\ModStartup.js
Comment out line 12:
// in_reg.RegisterEvent("ModStartupEvent",siOnStartup);
You can also disable the event using the plugin manager.
// Stephen Blair
Yay, it worked.
Thanks a lot Stephen :wink:
