Good News Everybody, Smoke is up and running....Thank you Robert & Brian
Here is how I corrected the problem, Follow Brian's post on this thread it has some go links to follow.
Here is a email he sent to me with another step I followed:
I have been following your thread... Robert is a true tech guy from Autodesk, so hopefully he can find the issue.
Here are a few tips and 1 question:
How did you put the media folder on the FW800, and what did you do with the original one it places on your system drive? Did you follow the steps and the video on how to do this by modifying the configs?
http://wikihelp.autodesk.com/Smoke/enu/2013/Help/z_Release_Notes#troubleAbout half way down the page and there is a video.
Tips:
1. Only have 1 internet connection active when you install Smoke. Pick ether or wireless.
2. If you used the other links I sent you shouldn;t have issues with DHCP when your IP changes (localhost) But you need to have an internet connection for Smoke to Start.
3. If you have your Media folder on a FW drive (properly setup) then that drive needs to be mounted as well to start.
4. The Stone+Wire relies and configs based on IP address.
I would suggest using the Smoke uninstaller and uninstalling Smoke. Then use the Go to Folder and go to /usr/discreet and delete the /discreet folder. This will completely remove all things Autodesk and Smoke. I assume you have no projects yet.
Then with only 1 internet connection... reinstall Smoke. Let it place the Autodesk media Folder on your system drive and then follow the steps and the video to use your FW800 drive and make a new folder.
Here is something I also did in addition to all of the steps above:
Here is what I've also done:
I ran disk utility and cleaned the disk permissions up
I uninstalled Smoke and reinstalled it and tried to start it up...same error
Closed all Airport connections (printer runs on it) rebooted... same error
One thing I did notice is that on Aug 2nd Smoke went into the designated storage disk and created a file called "Autodesk Media Storage" (this disk is running on firewire 800, if that is important)
I did notice if I go into the Smoke common utility, service utility that when I try to restart Stone+Wire it it disconnects the wiretap Server while it tries to startup S+W
Hope this helps everybody. I would follow the clean up of the discreet file and then re download a fresh free copy just incase
Thanks again to Robert & Brian they were a great help.
Butch Hirsch
