Pin Menus, Preview window and Smaller Advanced brush properties
hey, long time fan, loving the software, very easy to use and understand. But one thing stresses me out more than it should.
And that is that the canvas is behind menus and such, both active brushes and others.
Let me make my case, the default setting for the canvas is "Use width and height of window" which shouldn't be a problem if the above mentioned and this post wasn't written.
Some people my prefer this way of menu setup but others don't. It is really good that i have the freedom of moving them around to places that i want them, as it should be.
Now what i want is something in the line of Clip Studio, where the canvas area is set and "fit to view" doesn't end up shoving menus over the canvas. On that area, they have it really nailed down with how you still can customize your work space after your own preference. I would very much like that with a preview window and nightmode. Nightmode is super awesome!
other things that gets in the way of current canvas is the layer menu. it is super important and can't be closed.
Brush properties, something so good and important if you want to customize the brush on light and heavy pressure. that menu is soo in the way... FeelsBadMan... if that whole menu can get a copy in the form or a rectangular menu, similar to a... windows volume control! but smaller like the Sketchbooks Toolbar. and have Size, Opacity, Flow and Edge in it! And Size Opacity and Flow has each one "bar" (?) for Heavy pressure and Light pressure. very similar to what the menu looks like now but less big and flipped on the side.
Or just incorporate said menu as its own little menu like in Clip Studio.
