Navigation as in Photoshop - rotation on hotkey
Navigation should work as it does in Photoshop, pan with spacebar or middle mouse button and rotate using a hotkey. This is much faster to work with and less confusing.
5 Comments
You can rotate with 9, 0 keys
I set the touch ring on my tablet to these keys so I can rotate more intuitively. I still use spacebar to pan.
Intuos5
I'd rather get rid of the navigation puck entirely, so I won't have to look whether I'll be rotating or panning. I prefer to hit a key and immediately access a command.
This might as well be a user preference, if so, then allow the user to change the navigation behavior to their preferred setting.
joeaf9321
@Intuos5I think that your second comment is a better idea. So change the first one to:
Give the posibility of using different hotkeys for rotation, panning, and zooming while keeping the Navigation Puck Functionality.
Intuos5
@joeaf9321 This forum does not allow for changing idea posts, what I mentioined in my second post is in-line with the first. You can vote for the idea when the devs take it into consideration, the comments will also be looked at.
joeaf9321
@Intuos5  ok bro
