Adding clipping masks
You should add clipping masks in sketchbook pro it will make it easie r to add on other layer's instead of add and erace
11 Comments
I think this will great idea to add clipping masks it'll make an artist work easier and faster in my opinion and I was working on a painting and look for clipping masks
I was wondering if we could get a clipping mask feature for layers in Sketchbook? It's very time consuming and tedious when you want to shade or highlight, and cleaning it all up pixel by pixel makes it very annoying. Also, a folder feature for organizing layers would be great! I don't like the idea of having each individual layer together, and would much rather have folders to organize my layers. Thank you for listening.
You can emulate clipping masks using the lock layer feature on the layers menu.
https://www.sketchbook.com/help/knowledge-base/how-to-lock-transparency/
"lock transparency" works with only one layer, whereas you usually need to work on a separate layer.
colin.smith
colin.smith
colin.smith
colin.smith
clipping masks are in the backlog. Release date TBD.
YES. Honestly, this is the main thing that's been bugging me about Sketchbook. Mostly it's fine, but it's not working well with transparency and clipping and stuff and if they added clipping (and made it so the alpha channel exported with the actual colors instead of having a grey tint on all the semi-transparent pixels) I would definitely use Sketchbook a lot more.
Hello just to relatulise. If it was possible that SketchBook, as accepting Photoshop’s clipping mask by masking the stashed parts.
Please do this!! 😢
