Add HEX color scales for the color editor
 A lot of the color scheme websites that I use to get a color scheme only use the HEX color system, although HEX isn't supported in Sketchbook. As a result, I have to use Google's color picker to convert a color from HEX to RGB. Can you add a HEX color scale so I can just copy and paste the hexadecimal into Sketchbook's color editor?
4 Comments
patrick.muenster
I would like to add, that RGBA would be a nice improvement too. So that you can paint with transparent color.
That's also a good idea! But I have a question-- what's the advantages of
having an RGBA scale over changing the opacity of your brush?
patrick.muenster
If you paint a stroke with a brush with reduced opacity and paint over this stroke again with the same brush and opacity, the opacity is somehow multiplied or added together. So, after a few strokes you will have full opacity on that stroke. It's a like painting with watercolor over and over again until it is not transparent an<more.
A color with aplha value would limit this maximum of opacity to the set value.
That's a good point! Thanks!
Technology Administrators
