Hello all, I am using Autodesk SketchBook on iPad 6th gen (2018) and Apple Pencil 1st gen. When I use the time lapse recording feature in my sketches and select “Save to Photos Library”, the recording doesn’t show up in Photos. My iPad has a lot of free space so that is not an issue. I tried short/long sketches, the recording simply doesn’t show up. Please help.
Solved by david.lau. Go to Solution.
Can you check your preferences and confirm that you have access (read/write) to that folder? I have uploaded a video of my test. Near the end of the video is the 'settings' section of SketchBook. You can also try to restore preferences and when you save a time lapse, it will ask you for access to that folder.
