Hi. I was doing a quick drawing for a friend of mine and all of a sudden, my computer suddenly crashed when I opened a different program. I saved my project before that occurrence happened so I thought my project was fine. I forced shut down my Windows 10 laptop and tried to reopen my drawing, but as I tried it said, "File unsupported or Can't open this file". I checked all of my other programs such as Windows Photo Opener Or Paint and Even Photoshop, but to no avail. I even looked at my file manager and it says that the file is there with about 507 kilobites but it does not give me a Preview.
If anyone knows the answer to this, please help.
If anyone knows how to recover the photo or something check the attachment. It is the drawing that screams "Unsupportive".
Thank you.
Solved by david.lau. Go to Solution.
I am sorry to tell you that the sketch maybe gone. I would start using the 'save as' option in sketchbook. It will use the last name used and append a number automatically to 'version' the file.
See step 10 noted here: https://forums.autodesk.com/t5/sketchbook-forum/my-top-10-solutions-for-sketchbook/m-p/7238575/highl...
I found a potential solution. I opened my file that I'm having a similar problem with in the windows photo viewer. I can view the drawing that I spent countless hours on there. But it won't open in any other program. So what I did was I went to file then I click make a copy. It copied the image back onto my Autodesk images folder. I can continue working on it from there I just can't erase certain portions of layers. That's the best I could do and the only way around it in my opinion. I hope that you get this message before you give up hope
