SketchBook Forum
Hello Sketchbook Community Members! Sketchbook started a new exciting endeavor. This forum is now read-only mode. Please visit the new Sketchbook Help Center, https://help.sketchbook.com/ in the future. Happy sketching!
stepped lines with certain brushes
5 REPLIES 5
581 Views, 5 Replies
Hi there!
Unfortunately my lines of certain brushes have an inconsistent size growth when increasing the pen pressure.
The most often I am using the default brush "Design Pencil" besides a custom brush. Both have the same problem.
 Attached you can  find a picture of it.
I hope there is a solution to get a consistent line increase.
Thanks a lot for your help,
Greetings Georg
5 REPLIES 5
david.lau
What type of tablet are you using and what is the 'driver' version?
David Lau
in reply to: david.lau
Hi David,
I forgot the mention the most obvious...
It is the newest driver 6.3.34-3 of the "Wacom Intuos Pro M".
Georg
david.lau
I would try an older driver.
https://www.wacom.com/en/support/product-support/drivers
a. Uninstall Driver.
b. Reboot
c. Install Driver
d. Test SketchBook.
Use/Test:
Driver 6.3.33-3 (Windows 7, 8, & 10)
Driver 6.3.29-6 (Win 7, 8 and 10*)
Driver 6.3.15-3 (Win 7, 8 and 10)
NOTE: Wacom drivers are universal. They should all work with your Wacom M tablet.
David Lau
Thank you David for your response,
unfortunately in all 4 wacom versions appears the same problem (as seen in the attached pics).
Is there any other approach I could try?
Thanks a lot
Greetings Georg
david.lau
Check the stylus NIB and maybe replace it.  There are some spares in the Stylus 'stand'.
http://help.autodesk.com/view/SKETPRO/ENU/?guid=SKETPRO_Help_sb_basics_wacom_stylus_issues_html
I would try an older version of the driver via as well.
Drivers for Intuos3, Cintiq21, and Cintiq20 (DTZ) > Show older versions > Windows - Driver 6.3.14-1 (XP, Vista, Win 7, 8 and 10)
Lastly, if you are using the Wireless option on the Wacom tablet, I would use the USB option and not the bluetooth option.  See:   https://www.youtube.com/watch?v=8cjehwQa8Pg
David Lau
Technology Administrators
