So, after alot of tinkering with the installation of sketchbook pro, first I could not begin the installation process because of setupres.dll not loading, I managed to install it.
Then when I launched it I could not continue past the sign in screen because of a license network error. This made me uninstall and try different versions of sketchbook, sketchbook and sketchbook pro.
Now I managed to start a 15 day trial with sketchbook. But then I decided that I would try again with sketchbook pro because I have a serial key for that.
But now I can't even start sketchbook at all, it just loads a bit then nothing happens. No sign in screen, just nothing.
I have been trying to get this software to work for hours, and i'm out of ideas.
I am trying to use my student 3 year license
I have also deleted all sketchbook software and tried to reinstall, still no startup
Solved by david.lau. Go to Solution.
I have seen my fair share of fatal errors on Windows. As soon as I see a any .dll error, I will google it which you have probably already done. If you try any of the methods noted from your google search and spend more than 2-3 hours on it, my suggestion is to reinstall Windows on your computer. I have done many remote desktop sessions in my previous position and I wanted to share my experience with you.
1. dll = Dynamic Link Library
2. You may experience install error with other software.
3. Downloading .dll from other sites to replace it can cause issues. i.e. Malware
This points to 1 solution and that is reinstalling Windows. Start backing up your computer as that will probably take the most time. The re-installation of Windows (clean) will take about an hour depending on the speed of your computer.
I am sorry to tell you the news....
Tinkering some more, I've gotten back to the stage where I can launch sketchbook, but when I attempt to activate I get a licensing network error and the software shuts down.
