SketchBook Latest Update (No Login Required)
david.lau
Community Manager Community Manager
Message 1 of 10
david.lau
The latest update to SketchBook doesn't require a login anymore.  For more details:
https://blogs.autodesk.com/sketchbookpro/sketchbook-v-5-1-0-update-for-ios-android-windows-and-mac/
NOTE:  We have released an update to resolve a preference issue.  For more info on the issue, check out this post:
https://forums.autodesk.com/t5/sketchbook-forum/sketchbook-8-7-update-and-lost-settings-brushes-colo...
David Lau
Replies (9)
Message 2 of 10
I really like the latest update on my Win 10 Surface Pro 6. But i took a while to get it right. First the Windows Store refused to installed it or update. It remained same version. After trying and trying every trick I could think of to get it installed I decided to reset my Surface to initial installation and reinstall on a Clean Machine.
Now Everything works fine and Sketchbook Pro, latest release, is running on my Clean Surface 6.
Message 3 of 10
david.lau
We have updated to SketchBook 8.7.1 that moves the preferences folder back to the 8.0 folder.
8.0-8.6.x = 8.0 folder
8.7 = 8.7 folder
8.7.1 = 8.0 folder
David Lau
Message 4 of 10
david.lau
@Anonymous Have you been able to update to the latest version of SketchBook on Windows 10 (Store)?
David Lau
Message 5 of 10
I have, if it is  version 5.1.0. I was using it rigt now.. 🙂
Message 6 of 10
david.lau
I am glad you got it working!  There are 2 versions of SketchBook.
a. SketchBook Desktop (from www.sketchbook.com/thankyou) - it has all the tools and more.
b. Windows 10 version (from MS Store) - it is like the mobile version designed for Surface devices.
David Lau
Message 7 of 10
and I have it on my Surface Pro 6. The desktop version in my desktop computer. Both computers run with the same specs. Smooth as melting butter using Sketchbook. 🙂
Message 8 of 10
Thanks .. it helped us.
Message 9 of 10
Hello David! What about of my question? https://forums.autodesk.com/t5/sketchbook-forum/32-bit/td-p/9308390 Many Windows tablets do not have a 64 bit version of Windows!
Message 10 of 10
not supporr for 32bit. ver 8.7.1?
and where's the vendor should i contact😫
