This app works and I can draw like others on my Note 9, but I tried to save my first drawing and when I open the Gallery on my phone it crashes every time. I have looked at other forms and tried different solutions that were given, but the Sketchbook on my Note 9 still crashes. I honestly don't care if my 1 drawing is not saved, but I would like to save other drawings I do in the future. Can someone help me please?
Solved by david.lau. Go to Solution.
1. Backup Sketches!
2. Copy the Sketches from the /Autodesk/SketchBook3 folder to a desktop computer.
3. Confirm the the sketches are ok using SketchBook on a desktop computer
Download:
Login with your email address to confirm Sketches are ok.
4. On the Android device, create a new folder:
/SketchBackUp
5. Move ALL the sketches from /Autodesk/SketchBook3 to /SketchBackUp and DELETE /Autodesk/SketchBook3 folder.
6. Reset SketchBook
a. SketchBook > {=} > Preferences > Factory Defaults (4 options) - Reset all 4 options.
b. Settings > Application Manager > SketchBook (Delete Cache) - There are 2 Caches to reset.
7. Open SketchBook and import 1 sketch and test. Then import another Sketch and test.
Go to the heading: How to import SketchBook files from an older version into the latest version SketchBook for Android
https://www.sketchbook.com/help/knowledge-base/back-files-settings/
7. At some point, you can delete /SketchBackUp because the files will be duplicated in /SketchBackUp (via import) and /Autodesk/SketchBook3 folder.
Thank you for the info, but is there a way I can open the gallery on my phone because it still crashes and doesn't save my current drawing.
1. Delete App.
2. Delete /Autodesk/SketchBook3 folder
3. Re-download app and try to save/open files from Gallery.
