I accidentally deleted my iCloud data of the sketchbook app, and lost a lot of progress on the graphic novel I'm working on, is there any way to restore the deleted data. I saw somewhere on the website that I can restore deleted things for up to 30 days? But I do not know who to call, thank you!
Solved by david.lau. Go to Solution.
There are some tutorials on how to recover files but it will not work with SketchBook. You can try some of the steps noted to confirm for you.
https://www.techrepublic.com/article/how-to-recover-deleted-icloud-data/
When we save to the iCloud, we are not using the newer "File Folder" option (in the iCloud drive) that is in the newer versions of iOS. It will only sync with a "SketchBook" folder.
