Hi
I am using sketchbook in aSamsung Note 9 with an S pen. Is there a setting where the brush doesn't scale up relative to the zoom level of the canvas when the canvas is zoomed?
When you scale, you are only scaling the canvas. It will not scale the brush. I would open up the Double Puck and scale the brush that way.
http://help.autodesk.com/view/SKETPRO/ENU/?guid=SKETPRO_Help_sb_brushes_use_brush_puck_html
Thanks David. But in my app the brush does scale with the canvas. Maybe I wasn't clear so I will try to explain with an example. Lets say I draw a line, then scale the canvas and draw another line. Now both these likes have the same thickness. This is because brush size didn't remain static and scaled with the canvas. Several weeks ago I was able to scale the canvas without impacting the brushsize. For some reason that no longer works and I am no longer able to find any setting to do that if there is any.
When I used the Library > Basic > Pencil > I was able to change the brush size by adding more pressure when drawing. I am curious if that is what you did.
When I used the Draw Styles to draw a straight line, you are correct that zooming in or out will result in the same line width regardless of zoom level.
