Solved by david.lau. Go to Solution.
I am sorry to tell you that the sketches are gone. If you delete and reinstall the app, you delete the work in the Gallery.
Backup (iOS)
For iOS, the best method is to use the iCloud:
https://www.sketchbook.com/help/knowledge-base/how-save-your-work/
https://www.sketchbook.com/help/knowledge-base/use-icloud/
Saving versions of the artwork
To save a copy or version a file on the Mobile platform:
a. Start Sketch
b. Go to Gallery and start a new Sketch, It will ask you to save the file.
c. Go to the Gallery and start a new Sketch again and it will ask you to save the file.
d. Open the first Sketch and work on it.
e. Go to Gallery and start new sketch and choose the "Save as a Copy" option.
