Hi
Is there a way to make a drawing look like it is an ancient historical document in SketchBook?
E.g. like a layer that you can paste on top of a picture that makes it look ancient, worn, faded etc.
Or it could be like a layer to make it look like it was a scene from the bayeaux tapestry.
Kind regards
Xander
Solved by david.lau. Go to Solution.
SketchBook is for sketching. You want 'photo' manipulation....
GIMP is free, but check out this post for info on it as well.
https://alvinalexander.com/design/gimp-catalog-filters-effects-examples-cheat-sheet
I don't know if this works for your particular case... but I feel like I've done something similar.
I import a large monochromatic texture image, and make that layer a "darken" layer. I can also play around with the opacity. In the end it makes the existing drawing look like it was painted on parchment or historical paper.
