How to reset sketch orientation and zoom on iPad
I've just started using Sketchbook on an iPad Pro - and am new to both!
I've mastered the pinch gestures to zoom in and out, and the two finger slides to pan and rotate, but I am wondering if there is a nice simple way (that I haven't found yet) to reset the drawing back to the default full screen view, rather than having to carefully 'pinch' it back to 100%, rotate to 0 degrees, and then slide it back into place...?
Thanks in advance
david.lau
[=] > Preferences > Double tap Corner Shortcuts
You will notice top right is "Frame Canvas".  If you double tap on the top right corner, it should auto-center it.
David Lau
