How To Add (White) Outline To Drawing?
skinnymike1
skinnymike1
Hi all, I was wondering how you can surround your drawing in white like an extra outline coating, like this as an example:
Is it done manually, and do I do it on another layer? Thank you.
david.lau
It is a manual method.  You need to paint on it.  Only 'vector' apps can you add/duplicate or make an outline 'thicker' in the file.  SketchBook is a bitmap application.
David Lau
skinnymike1
Thank you for the reply and confirming what I was thinking! I really appreciate it.
This may be a convoluted workaround but I have found a theoretical way that I haven't tested but am sure of:
1. Make outline of lineart (either make the lineart , erase the insides and then copy to another layer, or trace the
    lineart's outline on another layer). Make sure this layer is beneath the original lineart. Name it the silhouette
    layer.
2. Make sure the lineart is closed and fill in with desired color with the Fill tool (twice to cover any gaps)
3. Now select the entire colored silhouette lineart and scale it to have it being slightly bigger than the original
    lineart (which should be above the silhouette layer).
And that should work!
Edit: Just tested it and it works! Well, mostly. You will need to move around the scaling to taste and manually add in extra paint to areas as needed.
Make 4 layers of the lineart, which is the desired colour. Then move each in a different direction, up, down, right, left. Use the nudge tool.
