Guides using multitouch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Guides are too slow!
A line should be able to be repositioned like a ruler. Two fingers, slide and rotate that thing over to where you need, draw your line, slide that guide where you need it, draw your line, repeat as needed.
The free default drawing app built in to windows 10 does this.
Sketchbook? No. You have to click one point, drag to where you want it. Then drag the next point to where you want it. Doing this over and over takes Way too much time.
Think that's not a big deal? Apply the same idea to ellipse and it's even slower. Drag to where you want the center. Drag one side scale, drag the other width, adjust the center because you probably got that wrong on the first try. Rotate, adjust again. Rotate, adjust again. You can't do multiple actions at the same time, so you have to keep adjusting.
OR, just rotate the thing with two fingers and maybe add a modifier of some sort (maybe just a third touch on the screen) for the non-uniform scale width.
Just try. Do something that would make this faster.
