Ellipse tool glitch
Ellipse tool glitch
j.aitken
Message 1 of 8
Ellipse tool glitch
j.aitken
Don't know if anybody else has seen this, and I didn't see anything online, but when the rotation is set to 0 or 90 degrees, the template screws up and jump across the center. I haven't been able to determine why it does it on one and not the other, nor which axis will cause it. If it does jump across, I can rotate the template 90 degress and resize it and it works fine, but I always have to make sure I do it on a clean layer in case I need to erase it and rotate.
Replies (7)
Message 2 of 8
david.lau
What type of tablet are you using?  I have seen this happen with Wacom tablets using 'older' Wacom drivers.
David Lau
Message 3 of 8
j.aitken
Neither. I was using a Logitech G series mouse. I was just messing around to test it so I could warn the artists at my studio about any issues before they look at implementing it in their pipeline.
Message 4 of 8
Had the same problem but found a way around it. I just rotate the ellipse tool slightly and that's it, the glitch goes away. After the rotation, if necessary I can place it back to its original position (0 degrees) and I'll be still able to use it without any problem.
Message 5 of 8
I've had the same problem as this.  We are using Wacom tablets and we are on the latest driver: version
6.3.32-4.  We've got a full classroom of students and this comes up regularly.
Any additional thoughts as to why this occurs?
Thanks!
Message 6 of 8
I too suffer this issue
Wacom Cintiq Pro 24. All drivers up to date. Quite frustrating when one can't draw a circle successfully.
Message 7 of 8
david.lau
This is typically a glitch with the Wacom driver.  I would use an older one.  Download each version (older) from here:
https://www.wacom.com/en/support/product-support/drivers
The Wacom drivers are 'universal' and work with all Wacom devices so you can go back to:
Windows - Driver 6.3.15-3 (Win 7, 8 and 10) <AS AN EXAMPLE>
Also, if you are using a Logitech Mouse, I would try to uninstall the Logitech mouse driver and see if it happens with the default Windows mouse driver.
David Lau
Message 8 of 8
rollingbits
I've Sketchbook installed on a Windows 10 machine and this happens there too. Changing the mouse doesn't affect it in any way. It looks like a division by zero problem. I think the programs sets a origin somewhere and every time the mouse crosses it again in a non-zero position a glitch occurs. Very annoying.
