Is it possible to create a default background layer? For instance, I would like to have a new drawing start with a preloaded grid as a layer over which I can draw.
Solved by david.lau. Go to Solution.
Not as far as I know.
But write it down as an idea in the forum.
This might be useful.
1 Set canvas size and resolution as necessary.
https://www.sketchbook.com/blog/trents-sketchbook-workflow-quick-tip-videos/
2. Create a file with a Grid Template (custom).
3. Save file with a nice description. i.e. 11x17 +300ppi+grid.tif
4. Set the file to 'read only'.
https://support.apple.com/kb/PH25287?locale=en_US
https://www.lifewire.com/what-is-a-read-only-file-2625983
5. When you open the file in SketchBook, the template will be set. If you save it, it will ask to save it to a new name.
Thanks. That's essentially what I did, but didn't think about the read only setting. Good tip!
