Creating a PDF for printing
Hello Sketchbook Forumites
I wonder if you can stop me going mad - this is probably so simple. Here is what I need to do:
I want to create a card, lets say it is 140mm x 140mm (made from a piece of card that is 140mm x 280mm), and prepare it for print as a PDF (I can do that bit) with crop lines. Previously I created a picture and I can crop that to 140 x 140 but I do not seem to then be able to resize the canvas in order to take the "back" of the card. I thought I would try and fool it so imported the artwork as an "image" but when I went to crop it, it just cropped everything. I have tried playing around with the image size menu and the canvas menu but to no avail.
If you can help then I would be very grateful indeed!
Rob S
david.lau
SketchBook can't export to .pdf for printing.  On the Mac, you can save/print to pdf.  On Windows, there are some 3rd party print to pdf options.
The issue is resolution.  You need to be at a least 300 DPI for printing cards.  I typically setup a 8.5 x 11 @ 300 DPI.
You can then create some crop marks for it.  The problem is the SketchBook's ruler is really a straight edge so you need to 'manually' create a file size accordingly...i.e.  140mm x 280mm @ 300 DPI
https://blogs.autodesk.com/sketchbookpro/trents-tips-what-resolution-should-you-use-anyway/
David Lau
Hi
Sorry been away on holiday and just seen this - thanks for your help appreciate that
Regards
Rob
