hello,i got a problem that when i started the SketchBook,the autorun quick tutorial cannot be closed.
system:win10 64
software:SketchBook_8.6.0.0_Win64.exe
Solved by david.lau. Go to Solution.
Fire whoever is responsible for designing this "X" and placing it. I restarted, uninstalled, re-installed, etc. It is barely visible.
OMG, I struggled with this for about an hour...thought it was a display setting as I swap between multi-monitors a lot. I JUST COULDN'T SEE THE "X" !!!! LOL
THANK YOU!!!
Dan
