Since a while ago, I've found an issues by changing my profile here in the forum.
By opening the edit mode of the About me section of my profile, the submit button is deactivated as long as I do not click in a input field of the Work information or of the Web Links.
Changing the text in the About me textarea alone will not activate the submit button.
I'm on Windows 10 using Firefox 62.0
1. If the space is blank or you want to deep it blank, can you just a 'space' in it.
2. You can also use another browser, if possible. If on Mac/Windows, just use the 'default' installed browser. i.e. Microsoft Edge/Internet Explorer or Safari.
Hi, David,
no, this has nothing to do with blank spaces and empty fields 🙂 . The event listener which triggers the submit button to be enabled on user input is somehow missing in Firefox. So you have to click somewhere outside of the textarea to make the submit button enabled.
In Edge and Chrome, the submit button changes its state directly after user input.
It's just a small difference but I recognized it by changing my profil. This can be confusing for the user (so it was for me), but it's not a big issue.
Indeed I don't know if it is a real bug or this behaviour just comes from the browser itself.
Maybe just keep it in mind.
