Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Brush settings, size
  • I'm using sketchbook and decided to make some custom brushes and i do like the basic pencil but i can't adjust the flow and other things about it like you can with advanced settings in other brushes. So i want to know if i can make a custom size range for my custom brush, an example would be that the basic pencil has size/hardness from 1 to 14 and a custom made one goes from 1 to 500 and i would want to limit it to 14 as well
david.lau
I would duplicate the Pencil and adjust it from there.  Check this one out:
https://blogs.autodesk.com/sketchbookpro/colored-pencils-a-free-brush-set/
You can download an entire set.  However, the customization of the size indeed will goto 511.
David Lau
