To Whom It May Concern:
Apologies if this has already been covered: I created a piece (please see the original enclosed below) for a friend using Sketchbook Pro Mobile v2.9.5 on a Samsung Galaxy Tab S (please see below). I also used the 1080p Canvas setting. Upon sending this to a print shop, they converted it to CMYK (since Sketchbook Pro Mobile v2.9.5 is in RGB), and when I got the printout, it came out darker and slightly blurry. Unfortunately, I don't have a picture of the printout. What steps do I need to undertake to insure the highest-quality printout using the aforementioned? AND is there a version which is in the CMYK color profile? Looking forward to hearing back. Thanks.
Solved by david.lau. Go to Solution.
Resolution: Typically, if I you are going to print, it should be 300 PPI/DPI. Please review the following:
https://www.scantips.com/calc.html
Once you have sketched at 1080 (size) x ????, it is still going to be 72 DPI so it will be blurry.
Color: That is a hard question to answer because even though you have converted RGB to CMYK, there are issues with your screen color calibration as well as color calibration when printing.
https://www.lifewire.com/calibrate-your-printer-1073954
https://www.cnet.com/how-to/how-to-calibrate-your-monitor/
For the Superman sketch you may need to use the color picker to confirm that the RGB values for the blue are the 'same'.
Thank You; However, when I clicked on those first 3 links, I got an error saying they were forbidden.
So, long story short, after I use my high-quality setting in the sketch stage, I should convert it to the suggested DPI before printing, correct?
You need to re-draw it at 300 dpi or the equivalent resolution. Please try the links again later, we are in the process of fixing permissions of the 'help" documentation.
