Please make a 32 bit version of the application on Windows 10!
Solved by david.lau. Go to Solution.
@Anonymous - that post is more suited for the IDEAS forum.
See this link: https://forums.autodesk.com/t5/sketchbook-ideas/idb-p/804
Also, Please vote on this one. You may not have arm, but having continued development will help everyone. https://forums.autodesk.com/t5/sketchbook-ideas/windows-10-arm-suuport/idi-p/9061187
In the meantime, here is the link to an older 32-bit install.
https://filehippo.com/download_sketchbook-pro_32/
Why I still have not received a response from the official autodesk?
The majority of people posting here are just users like you. Have you actually contacted someone with Autodesk?
The last version that was 32 bit is 8.5.x.
Thanks David! Why ceased to support 32 bits? Do you plan to support 32 bits in the future? Many Windows tablets have only 32 bits!
The last version (8.5.1) that was 32 bit can be downloaded here:
If you login, you can access the entire app (functions) for free.
Thanks, David. I appreciate the link, but I'm aware this is available and it's what I have been using. However, the lack of pen mode, and rotation support make it quite annoying to use.
This is why myself and others are hoping for support for Arm64 architecture on windows.
Please consider this for the Window 10 app.
@david.lau could you please help me, my computer's system is 32 bits, I would like to download the Autodesk Sketchbook for my computer with 32bit system, but the link is not working
Hi Kleccio,
Have you found a solution yet?? My computer is 32 bit too and I would like to download Sketchbook!!
Thank you : )
