The Simulation Mechanical Idea Board has been closed down and placed in read-only mode following a recent discontinuation announcement. Please see our supporting FAQ for more information.
Import clc files
Import clc files
We regularly use "combine load cases".  However creating the load combinations in the embeded load combination utility is tedious.  It is much easier to do it externally.
It would be a great time saver to be able to import .clc files and then run these.  Our normal mode of operation is produce a .clc manually and then run it from a dos window.  When there are 100 or so lines to enter the internal method is impractical.
