Surface contact creates elements which can be hidden simply by isolating a part in the model. But there is no means to display the contact elements again! This functionality is needed in order to view which elements are in contact ("Results Contours > Other Results > Element Forces > Axial Force").
The user should be able to:
- use the "Results Options > Element Visibility > Show All" command. This command does not display the contact elements in SIm Mech 2014.
- right-click on a contact pair in the browser, or on the parent "Contact" branch, and have options to display or hide the pair.
The current work around (create a new presentation window) requires the user to re-do a lot of work if custom legend, part visiblity, slice planes, shading, and other settings have been chosen.
John Holtz
