The Simulation Mechanical Idea Board has been closed down and placed in read-only mode following a recent discontinuation announcement. Please see our supporting FAQ for more information.
Add a "point selector" tool to the joint creation utility
I want to be able to graphically pick the joint center points while I am defining them
In 2013, you have to either manually type the midpoint coordinate or let the software do it for you automatically.
Another option for "picking" the coordinate of a universal joint is to create the joint using either of the options, and then use the "Draw > Modify > Point Move" command to relocate it to the desired point. But this is only a workaround at the moment.
2 Comments
Sualp.Ozel
Status changed to: Accepted
Sualp.Ozel
implemented in the 2016 release
Technology Administrators
