I'd like to be able to quickly see the 3D visualization of beams while in the FEA Editor without having to run 'Check Model' to see them in Results. Running 'Check Model' on a beam- or truss-only model is generally very quick and not a problem. However, I'm using more mixed meshes now and many are very large models. So the Check Model step just to see if I have all the desired beam cross-sections and all the right orientations can take a while.
