When using Design Scenario copy command, 'Surface Groups' have disappeared.
Message 1 of 13
I copy design scenario (DS) 1 into DS2. DS1 includes two Surface Groups and one Surface Contact Pair (using Surface Groups).
Please see attached movie file (SWF).
After copying DS1 into DS2, I returned to DS1. Then, I returned to DS2, I found that the Surface Groups and Surface Contact Pair have disappeared.
Is this a technical issue?
Attached ZIP file includes ACH file and movie(SWF) file.
Best regards,
Amatsuda
Replies (12)
Message 2 of 13
I have the same problem, but i can't find any solution.
How do you solve this problem?
Message 3 of 13
Message 4 of 13
rlkillian
I tried this in ASM 2017 and got the same erroneous behaviour.
Message 5 of 13
Hi rlkillian,
I installed ASM 2017 last night, I also tried this.
Unfortunately, I got same issue....
I'd like to contact local Autodesk technical support, about this issue again.
akihiro
Message 6 of 13
I notice that this error appears only when I select MES analysis.
For example with linear analysis the copied design scenario works correctly.
Message 7 of 13
Hi andrea!.
Thank you very much for your new information.
I will add this when I make a case report to the Autodesk.
Message 8 of 13
This issue was re-accepted by Autodesk Support Team and was transferred to Development Team.
Thanks all !
akihiro
Message 9 of 13
John_Holtz
Autodesk Support
Autodesk Support
Hi everyone,
A coworker discovered a work around. After copying the design scenario, edit the name of one of the selection groups. I tried it with Sim Mech 2017 and changed the name of one of my selection groups (the model had 4), and it worked.
Let us know if it works (or doesn't work) for you.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Message 10 of 13
Hi John,
The proposed workaround works well!
I hope that this issue will be essentially improved in next service pack or hotfix.
Thanks again,
akihiro
Message 11 of 13
benalain13
I confirm this is an old issue.
OK for the workaround but what about the fact your model does not have any group...?
So, the best should be to have a perfect copy command.
Message 12 of 13
Malenki
I have a very similar problem, perhaps it's the same - phenomenon for some time.
I have open project (scenario 1) with assembly made up of many parts (linear analysis). I was allocate the parts of the group and stored in the Selection Groups of TreeView section for convenience. Simulation run properly. Now, I copy the scenario to the new one. There, I changed the attributes of a part or the whole group, such as visibly, isolate, supres... Than I remeshed parts of an Assembly when needed with cheked, or once I run the Simulation. It was all right for the time.
For some moment (this same version 2017), after the remesh or simulation is run, list of Selection Groups in the current scenario is cleared. It is completely empty!!! Why do I suddenly part of the group again for each copied scenario? I have tried various methods of recovering this list to second scenario - to no avail.
I have the impression that the problem appeared after the June 2017 update ASM.
BTW.
Using Selection Groups section created files like project_name.group###.xlg" in the directory of .fem file. There is no in-line help information. Something about this?
Regards
Malenki
_______________________________________________________
Windows 10 64B + Product Design Collection 2021+ASM 2018
1. HP Z2 Tower G4: Intel Core i7-8700K [email protected] + Quadro P2000
2. GIGABYTE EX58-UD5: Intel Core i7 920 (2.66GHz to 3.6GHz) + Quadro FX4000
Message 13 of 13
Malenki
Your advice is good, very good and its works. But, this is only a prosthesis. What about Selection Groups in other scenarios? I was eight. Whether (and how) to move them from the original scenario to those of the cleaned-lists of Selection Groups section?
Regards
Malenki
