Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Using Variable Surface Load with a Cylindrical Coordinate System
1 REPLY 1
andrewdroth
428 Views, 1 Reply
andrewdroth
I'm trying to figure out how surface variable loads are defined by functions in a cylindrical coordinate system.
I tried a simple test. Make a cylindrical coordinate system with the origin at the top of the tank, and the positive Z pointing to the bottom.
I then applied a surface variable load to the shell wall. The function is R = s, therefor the pressure should increase from 0 to 6.3 as it goes around the tank.
The Variable Load Viewer confirms what I want to achieve.
But when I run the model, the pressure increases to pi radians (180 deg) in the positive and negative directions.
I was expecting it to steadily increase positively all around the tank.
Anybody have an Idea why it splits?
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
Andrew Roth
rothmech.com
1 REPLY 1
andrewdroth
in reply to: andrewdroth
andrewdroth
By changing the equations to ABS(s) I can get it positive both ways. But I'm still not sure why it counts up to pi radians in each direction.
Andrew Roth
rothmech.com
Andrew Roth
rothmech.com
