Surface Meshing Errors from Surface Model
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
To the community,
I have a rather large model (200+ parts) that I have converted to a shell model using an external program (solid edge). I saved the file by .stp conversion, and opened in Simulation Mechanical. I am able to get 90% of the mesh generated by tweaking global and local mesh options. I have tried just about everything with all the settings to get the mesh 100% watertight/uniform, but I am finding some very strange issues.
I have been planning to use shell elements (assuming this is the equivalent to ANSYS Shell 181 element type) in a non-linear structural analysis. The model has a few solids in it, as I am analyzing a local bolt failure, and looking for strength improvement ideas. Using the bolt mesh generator in past analyses, I have found that when the mating parts are meshed as solids, it works much better.
I have tried manually "filling in" areas where the CAD geometry is disappearing, but unsure if that will be a good solution. I was using the features in the "draw" tab, such as line creator, and the 3 and 4 point mesh found in the "mesh" tab. After drawing the mesh/lines in the proper parts/surfaces/layers, I can not define the element properties, so I assume these added meshes would adapt the part's defined properties that I drew them in. Is this a good proceedure for repairing these issues?
I have tried re-importing as .x_t and .iges files, and running into the same errors, if not worse. .stp has always seemed to work the best for me.
Additional notes:
As meshed in the images attached, I have added more and more refinement, much more than I think is needed, and likely encroaching on very long solve times. I'd prefer to use the bricks for the solid mesh, and used tets when I had difficulties.
I am running Simulation Mechanical 2013 on Windows 64bit computer.
I greatly appreciate any thoughts. I need to solve the watertight issues with the solid mesh, and repair the missing geometry in the surfaces. I would be glad to share files as needed to further diagnose. Thank you in advance.
